April 12, 2022 at 10:12 am
lkl
SubscriberHi,
I am new to ansys and I am modelling a rail with springs below with two fixed ends. However, I getting the following warning message, is this a concern or how to eliminate it and how to check the created beams on solution information?
April 13, 2022 at 10:58 amAshish Khemka
Solver pivot error generally indicates rigid body motion. Please check if the model is constrained properly.
Regards Ashish Khemka
April 13, 2022 at 2:53 pmlkl
Subscriberto check if the model is constrained properly as in the fixed support and the spring? How come if the meshing size is smaller, I do not encounter this error?
As for the warning msg of one or remote boundary condition has been scoped to a solid vertex, is that a concern or how to I remove it?
April 15, 2022 at 4:33 pmlkl
SubscriberHi Appreciate all assistance on my queries. Thank you.
April 15, 2022 at 4:42 pmAshish Khemka
Can you share the images of how springs are connected to the rails? The connection may be changing with mesh.
April 16, 2022 at 6:21 amlkl
SubscriberHi @akhemka
I have done a face spilt using as a vertex as connection from a body to solid connection and below is my image of how the spring is connected with mesh image.
If I used a lower body sizing, it will only reflect the warning as shown below. Is this a concern?
If I increase the body size, it will show four warning and error messages.
Appreciate your advice.
April 19, 2022 at 5:28 amlkl
SubscriberHi @akhemka Can assist?
Thank you.
April 19, 2022 at 6:01 amAshish Khemka
The warning message appears when you scope the remote point to a vertex. Also, please see if the following discussion helps.
Attaching a point mass on a beam in Modal ÔÇö Ansys Learning Forum
Viewing 7 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2156
1359
1150
462
