Tagged: 1-way-fsi, 2-way-fsi, fluent, system-coupling, transient-structural
March 21, 2022 at 5:51 pm
mohammedlaminemekhalfia
SubscriberDear All ansys users.
I am performing a one-way and two way fluid structure Interaction, my objective is to plot the displacement of a point at the tip of canilivred beam against time.
the Pressure input was 1 bar stepped so I choose the transient solver and I used a profile that describe this step function.
I monitored the velocity and the total absolute pressure on the beam surface which are a good fit to the calculated values. below the velocity magnitude
March 21, 2022 at 5:53 pmmohammedlaminemekhalfia
SubscriberThanks in advance for your kind advices
March 22, 2022 at 10:55 amRob
Ansys EmployeeSee if you can add a separate Results section, then link Mechanical and Fluent to it. Otherwise one forMarch 22, 2022 at 11:44 ammohammedlaminemekhalfia
Subscriberfor the one way FSI, I tried to change the solver to static and import the load from fluent in different methods yet, I have the same result just one point plot or the curve in the figure attached to the original post, I read in some previous post that I need to add a data transfer section but it was not very helpful as I think it is possible if the data are few but in my case, I have 40000 points so...
for the 2 way FSI, still the same I tried to add a new results section and even start a new project but I still could not link the two sections.
Thanks a lot for the reply
March 22, 2022 at 12:20 pmKarthik R
AdministratorHello:
Please refer to the tutorial I shared with you here and see if this addresses your issue.
Problem with Coupled 2-Way FSI ÔÇö Ansys Learning Forum
Karthik
March 22, 2022 at 2:00 pmmohammedlaminemekhalfia
for my first part with one way FSI, I could not find any resources about ''data transfer'' as in some of the previous post they mention that this the solution of the problem of ready transient displacement in structural analysis section
March 23, 2022 at 3:28 pmStephen Orlando
For your second question, please see my response here: https://forum.ansys.com/discussion/comment/132807#Comment_132807
Steve
Viewing 6 reply threads- You must be logged in to reply to this topic.
2706
2142
1357
1144
462
