One way coupling
    • Ansan
      Can we use the one-way coupling for coal-oxygen combustion?n
      One way coupling of what? n
    • Ansan
      I mean when I don't choose to use interaction between the phases available in DPM model.n
      If you don't couple the phases the particles can't effect the flow:so no matter how hot they get the coal can't burn as it can't interact with the oxygen. So you need to select interaction between the phases. n
Viewing 3 reply threads
