LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK visualization
    • Pratik Ganorkar
      I am using ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK, is there any way to visualize the extent of tiebreak contact breakage like finge plots of stresses and history variables.
      Thanking you
      Pratik Ganorkar
      MTech, IIT Goa (2021-23)
    • Ram Gopisetti
      Hi, onw way is to use SPR and MPR in the ONE_WAY_SURFACE_TO_SURFACE_TIEBREAK card and use S=INTFOR in the run expression you can get the contact gap contours in intfor, check the binout for RCFORC for tie area and z_force curve as indicater when the tie got break.
      cheers, Ram
