LS Dyna
LS Dyna
“Only linear and rigid equations of state are valid for shells” – Error ACP-Explicit coupling ?
    • Mjaiman
      I am trying to conduct a Carbon Fibre helmet assembly drop test using explicit dynamics autodyne solver and getting the following error message- "Only linear and rigid equations of state are valid for shells".
      The helmet has two parts - Shell (ACP) and polyurethane foam (Ogden 3rd Order Hyperelastic material model). I have coupled the systems as shown in the picture below.
      Please if anyone has come across this error let me know what I might be pursuing wrong?
      Here is the solver output message:
      License acquired!
      Checking model setup.....Please wait
      Generating External Faces ...... please wait
      Initializing.....Please wait
      ERROR! Cannot run problem. Invalid equation of state with SHELLS.
      Valid equations of state for SHELLS are:
      Linear and
      Rigid
      Cannot run problem. Invalid failure model with SHELLS.
      Valid failure models for SHELLS are:
      None
      Plastic Strain
      Principal Stress
      Principal Strain
      Principal Stress/Strain
      User failure #1
      Finished model setup with errors...
      I tried suppressing failure constants for composite materials but did not find any success.
Viewing 0 reply threads
