Photonics
Photonics
Only one mesh constraint per simulation?
    • Mariah Ha
      I have been trying to use two mesh constraints in the same charge simulation (one on a cylinder and one over an interface that needs more meshing) but the solver only applies the first mesh constraint and ignores the second (which is under it in the object tree) . Is there any possible causes for this? Did anyone encounter this ?
      Regards.
    • Khashayar Ghaffari
      Can you share a screenshot of the Objects Tree wich shows the objects hierarchy ("model", solver, and the two mesh objects). As you suggested multiple mesh objects should be applied at the same time. This might be a software error specific to the objects hierarchy. Your update will be helpful in determining this. Also, what is the software version you are using? Thanks.
