August 5, 2018 at 4:06 pm
August 5, 2018 at 10:09 pm
SubscriberBuild a bigger breakwater?
August 6, 2018 at 12:25 pm
August 6, 2018 at 12:48 pm
Ansys EmployeeHow have you created the blockage? I ask as the free surface looks to ignore it, and as it ought to be a void (no mesh), that doesn't make sense.
August 6, 2018 at 2:01 pm
August 6, 2018 at 2:07 pm
Ansys EmployeeYes.
Please read up on Boolean Subtract. In isothermal models you only tend to model the fluid bit, you've got overlapping mesh and the box isn't doing anything other than confusing the results.
August 7, 2018 at 8:29 am
DrAmine
Ansys EmployeeHi,
It might be that the blockage is ignored as you are initializing with the wave. Carry out the run and tell us what you are seeing.
August 8, 2018 at 7:38 pm
Shafaq
Subscriber -
August 9, 2018 at 11:02 am
Ansys EmployeeLooking at that result, the wave has gone over the blockage and you need to check the back flow on the outlet to make sure the water can leave. The water-air interface also looks diffuse so you may also need to refine the mesh in that area.
2066
1285
1096
459
