Ansys Free Student Software
Topics cover installation and configuration of our free student products
Open Hyperworks file in Ansys Workbench
    • Zimeng Jia
      Dear Ansys technical support,
      I encounter two problems when importing Hyperworks mesh file in Ansys Workbench.
      1. I try to import the hyperworks mesh file as NAS. filetype, and after click the update on the 'Setup' block, there's an informational messages as followsCould you please help me with what the 'user input' it is required to update and see the model in Static Structural?
      2. I try to import the same hyperworks mesh file as CDB file type, I have also unchecked the box which says' check valid cdb file', and this time there's an error message as follows:Looking forward to your kind reply!!
      3. Thanks
    • Ashish Kumar
      Forum Moderator
      Try using the unsupported feature - FeModeler. Go to Tools-> Options -> Appearance and then check mark the Unsupported Features:
      On the left side in the Toolbox you will be able to see FeModeler:
      You can import the mesh using this tool.
      Ashish Kumar
    • Zimeng Jia
      Hi Ashish,
      Thanks for your immediate reply. Following your instructions, I have this error :
      1. I right click on the 'Model' cell of the Finite Element Modeler ( Unsupported), then I choose the cdb mesh file
      2. After I chose the cdb mesh file, the Finite element modeler automatically pops out, but it shows the error below:
      Is my way of choosing the mesh file incorrect or is it something dealing with student license?
      Thanks
    • Ashish Kumar
      Forum Moderator
      It seems that you do not have the license available.
      Ashish Kumar
      • Zimeng Jia
        Hi
        I'm on a student license, Do you mean the student license does not allow importing hypersorks CDB file into ANSYS?
        if so what's the way to import Hyperworks CDB mesh file into ANSYS WORKBENCH then?
        thanks and looking forward to your help!
    • Ashish Kumar
      Forum Moderator
      Can you please check why you are in Read-Only mode (as per the error message)? Please try closing out and reopening the model.
      Ashish Khemka
    • Zimeng Jia
      I've closed all, cleared all, and reopen the files. But both the .NAS and .CDB files how the same error ' '.
      As what the error message shows, I wonder if it's because of 'ran out of available licenses'? Can we have an online instruction meeting if possible please?
      Thanks !
    • Ashish Kumar
      Forum Moderator
      Please refer to the following posts:
      Licensing error while opening ANSYS Mechanical
      Read only (ansys.com)
      Ashish Khemka
    • Zimeng Jia
      Hi Ashish,
      I followed the posts Licensing error while opening ANSYS Mechanical, deleted the previous versions, and redownloaded Ansys 2022 R2 (V222).
      Then, I followed Read only (ansys.com), but it says
      So I cannot launch the 'License Preferences' GUI.
      I'm so sorry for the inconvenience, is it possible if we have an online meeting so that you could take a closer look and advise me?
      Thanks
      Amber
    • Zimeng Jia
      Hi Ashish,
      I tried to open the cdb file in Workbench 2020R1, by following the way you suggested using unsupported feature. However, I encountered a different error than the 2023 version, and its screenshots are attached  below:
Viewing 8 reply threads
