LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
OpenMPI with lsdyna mpp
    • Wasif Safdar
      I am trying to use OpenMPI with lsdyna mpp on linux. Here are the details:
      • OpenMPI version 1.10.7
      • lsdyna version Version : mpp s R13
      • Compiler Intel Fortran Compiler 19.0 SSE2
      The problem arises when I try to use $ mprun -np 2 /PathToExecutable/ansys231 pr=dyna i=input.k -lsdynampp, it starts two similar lsdyna processes instead of running lsdynampp on two processors. So I guess it is running mpirun to start the process, and then uses intel mpi to solve the actual simulation on the processors.
      How can I solve this problem?
    • Ushnish Basu
      MPI by definition runs muitiple copies of the specified process, with appropriate communication between them. Whether those processes run on the same machine/node or not depends how the hostfile is specified, e.g. see the questions on hosts here: https://www.open-mpi.org/faq/?category=running
      Also, doing a google search for "mpp bind to core" should take you to a page how to make sure LS-DYNA jobs don't migrate from core to core during a run
