November 13, 2018 at 3:49 pm
giovanni_ianziti
SubscriberHello,
I`ve a closed volume with inside liquid (0.13 vol fract) and mixture of air and vapour (0.87).
The pressure inside the volume is 20000 Pa, is this value the operating density?
Is the operating temperature the minor value in the system? for example in my case I`ve a wall with a temperature of 10 C and is the minor (in the boundary conditions).
I`m not using Boussinesq approximation so how can I decide the operating density? When can I neglect it?
Thank you
November 13, 2018 at 11:15 pm
Karthik R
AdministratorHello,
I'm moving this post to the 'Fluid Dynamics' thread for more traction.
Operating temperature should be used only when you are using a Boussinesq approximation for natural convective flows. This is only valid when changes in density are small. You can use the minimum temperature in your system as this operating temperature. Please read more about this in the Fluent Users Guide (section 12.2.4.2 - The Boussinesq Model).
About operating density: please see the following screenshot.
Please refer to the users guide for more details.
I hope this helps.
Best Regards,
Karthik
2524
2066
1279
1096
457
