March 4, 2023 at 4:44 pm
Celal Kermangil
SubscriberHello,
I have been analyzing the CFD of the quadcopter for a compressible fluid at the 10-meter flight. Should the operating pressure be 101325 Pa or should I change it for my simulation?
Thank you.
March 6, 2023 at 7:48 am
SRP
SubscriberHi,
For compressible flows with higher Mach numbers, operating pressure is less important. Since the pressure variations in these flows are significantly larger than those in low-Mach-number compressible flows, roundoff error is not a significant issue and gauge pressure is not really necessary. In fact, it is customary to perform these computations using absolute pressures. Just setting the operating pressure to zero will make gauge and absolute pressures equal as Ansys Fluent always utilises gauge pressure.
Thank you
3744
2573
1795
1236
594
