February 28, 2022 at 9:00 pm
Danc08
SubscriberI am getting the following error :" Operation will result in non-manifold bodies " after I try to subtract my geometry using boolean. I am currently using a .iges file which could be the problem, since when I open it some bodies are categorized as surfaces and others as solids. I tried creating a solid using a body operation but it was unsuccessful. Please help.
March 1, 2022 at 11:32 amRob
Ansys EmployeeIt's a problem with the CAD shapes/overlaps. Have a look on here or Google for an explanation of what the error means.
March 1, 2022 at 7:23 pmDanc08
SubscriberI have already tried looking here and google. What I found was that since some bodies were imported as solids and others as surfaces, the surfaces did not have a definite volume within the boolean, so I tried creating a body operation to make the surfaces solids, but I also got an error there and I was not able to do that. Could you please provide me with some more specific solution?
March 2, 2022 at 11:40 amRob
Ansys EmployeeIt means that some of the bodies contact with a zero area or create volumes which have no volume. The surface contact is often two circles (annular faces) that touch at a single tangential edge. Because they're bodies that touch the contact is surface but the area is zero. The solution is to identify these regions and fix them.
March 2, 2022 at 6:18 pmDanc08
SubscriberIs there a specific tool that can help me identigy this zero area point of contacts?
March 3, 2022 at 11:29 amRob
Ansys EmployeeSmall edges can do, but otherwise it's a case of looking at the model to see what's going on.
Viewing 5 reply threads- You must be logged in to reply to this topic.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2666
2120
1349
1132
461
