March 21, 2021 at 12:36 pm
AjayKumar69
SubscriberContext: Geometry Engine, while generating Feature Enclosure1
I'm trying to create an enclosure for a roll cage of beach buggy that I've designed but I just can't create one. I keep getting the error mentioned above. Please help as soon as possible. I've added a screenshot of the error and also the model of the roll cage to this.
March 22, 2021 at 4:17 amKeyur Kanade
Ansys EmployeePlease check geometry with tools -analysis tools - fault detection. nIf geometry has any faults, please correct them. Then use enclosure. nIf it still gives error, try to unite your 91 solid bodies. nIf you have any surface bodies then it may give errors in creating enclosure. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynnViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
