Optical
Optical
Topics relate to Speos.
Optical fiber sensor
    • Karthik Buddala
      Hello everyone,
      For my project i need created two optical fibers sensors in a container with completely filled oil. I need simulate a electric arc in the oil container and after that rays passing through optical fiber.
      My question is how to create liquid material in speos like oil in the container
    • tallurkn
      You can create a body(Ex: A cube) using sketch features, then you can assign the optical properties of the oil.
      For example, Volume property (RI) = 1.5  Face optical property = optical polished.
      Ansys
    • Karthik Buddala
      Thank you so much for your help.
      I created a two optical fibers of 1mm diameter in vertical direction. I create a source next to those two optical fibers. When i simulate it. Actually no rays passing through a fiber. Please kindly help me with soultion.
      Thanks
      Karthik
