March 3, 2022 at 3:08 pm
Mariah Ha
SubscriberHi,
I am trying to specify an optical generation rate in 2D FDTD. I specified its geometry to be 2D as shown in the first picture. But when I import it in a the 2D Charge solver (same structure) to perform the electrical simulation, the solver automatically adds a third axe in the optical generation geometry, and does not allow me to modify the span of the third axe to be 0 (see second picture) , to keep it exactly as the 2D FDTD geometry. The span is blocked in grey color and cannot be modified. Can someone explain why is this happening ? Why does it modify the optical rate geometry to be 3D ?
March 4, 2022 at 7:35 amKhashayar Ghaffari
Ansys EmployeeHi Thank you for your question. This is the expected behavior for the exported data; the 2D data set will have 2 points in the third direction (instead of 1). This will not interfere with the data and the 2D profile will be applied correctly as long as the defined box includes your 2D charge simulation region. To check this you can switch the CHARGE simulation to partition mode and click on the imported data.
Best regards
March 4, 2022 at 10:15 amMariah Ha
SubscriberThank you for the clear answer. For 1D case is it the same ? I mean the generation rate which is defined in 1D FDTD , will it be automatically 2D when imported in charge solver ?
March 5, 2022 at 12:14 amKhashayar Ghaffari
Ansys EmployeeNo problem. No, if you want to import the data for a 2D CHARGE simulation, it has to be set up to have a 2D profile. If you want to run a 1D FDTD simulation anyway (assuming uniformity for the profile), a workaround is to copy the 1D data across the second axis to create a uniform 2D profile. For this you would need to post process the data through scripting.
- Error on Lumerical device
2726
2148
1359
1150
462
