September 25, 2023 at 9:41 am
qiang wei
SubscriberIn the 1st model, I set the demagnetization calculation.
In the 2nd one, which has the identical geometrical parameters with the 1st one, the demagnetization calculation was cancelled, and a PM field was added to link the 2nd with the 1st.
I wanna do optimetrics (sweep different current amplitudes) in the 2nd by applying the demagneitzed PM field calculated in the 1st model.
However, the 2nd calculation process always fails to get the results from the 1st one after running for several hours, and stopped randomly.
September 26, 2023 at 6:51 pm
HDLI
Ansys EmployeeHello Qiang Wei,
In 2nd model, do you do following steps? Linking is not in analysis ->setup.
1). Select PM from the history tree
2). Menu item Maxwell 3D/2D → Excitations → Assign → Permanent Magnet Field…
3). Check the radio button Demagnetization
4). Click on Setup Link…
5). Setup General, Variable Mapping, and Object Mapping tabsPlease go to ALH, demagnetization, two step approach
HDLI
- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1680
1470
