November 26, 2022 at 4:34 am
November 28, 2022 at 5:48 pm
Guilin Sun
Ansys EmployeeIn general, if the data matrix size changes during the sweep, or if you sweep wavelength/frequency, such issue can occur.
Please check what do you sweep, and if the R monitot is changed during sweep?
If problem still exists, please paste some screenshots of your settings, such as the monitor, and the sweep etc.
- Error on Lumerical device
2524
2066
1279
1096
457
