March 22, 2021 at 10:16 am
smraniaki
SubscriberAny Ansys official doc explaining the optimization algorithm and the theory behind them? n -
March 22, 2021 at 1:51 pm
Karthik R
AdministratorHello,nWhich product are you using? And which model are you referring to?nKarthikn -
March 23, 2021 at 1:37 pm
smraniaki
SubscriberKarthik,nI meant the algo used in the design of the experiment, response surface, and optimization modules. n -
March 23, 2021 at 1:43 pm
Ansys EmployeeWe have several optimisation options so you need to check the documentation for that particular solver/tool. Clicking on Help in the later versions of the code will take you to the documentation. n -
March 23, 2021 at 2:03 pm
smraniaki
SubscriberRob,nDo you mean the WB help (Ansys workbench help, and workbench context help) that normally appears on the sidebar? There I only see an abstract (one line) description of the modules. I can't find a detailed theory implemented for the models. Similar to fluent doc that contains all information about governing equations, parameters, etc.n -
March 23, 2021 at 2:09 pm
Karthik R
AdministratorHi,nTake a look at this DesignXplorer User guide link.nKarthikn -
March 23, 2021 at 4:17 pm
Ansys EmployeeNo, Help is the entire product documentation. n
- Workbench error
- Workbench not opening
- License Error
2706
2138
1355
1144
462
