November 30, 2020 at 2:13 pm
Abdou1
Subscriberhello
it is possible to enter the goal as vector data ,
December 7, 2020 at 6:46 amAndyJP
Subscriberit is possible setting multiple goals and a specific frequency per goal.nDecember 7, 2020 at 12:36 pmAbdou1
Subscriberthere is lot of point !!nDecember 9, 2020 at 10:33 amrtk
Ansys Employee,nIf your intention is to add several goal values corresponding to different frequency points, then try the below workflow:nAfter selecting the required calculation, follow the below procedures in the speculated numerical order.nnBy this way, you can add the frequency points and required Goal value.nHope this addressed your concern. Happy Simulation!nnBest Regards,n
Viewing 3 reply threads- The topic ‘Optimization goal as vector ?’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1688
1478
