March 5, 2022 at 8:15 pm
williamfraser3
SubscriberI have created a project in FDTD where I am trying to optimize some parameters of a metasurface to maximize the intensity of the E field at the focal spot. I have a point frequency-domain field and power monitor positioned at the center of the focal spot. In the optimizer, I have the E result from this monitor set as the figure of merit in the Setup tab then I use the following line to calculate the intensity as fom in the figure of merit script.
fom = sum(abs(E)^2);
I let it run overnight and it seemed stuck at 1 for a while until the fom shot up to 25:
March 8, 2022 at 12:10 pmGreg Baethge
Thank you for posting your question. I tend to find the custom figure of merit a bit tricky to troubleshoot, sometimes, so I would suggest to use "model" as an analysis group, to calculate the custom FOM there and use it directly in the optimization task. I think it is easier and you can check the figure of merit is properly calculated just by running the simulation and checking its value.
I hope this will help!
March 8, 2022 at 3:26 pmGuilin Sun
Ansys EmployeeIn this case, please use the same result as the FOM. In the Optimization GUI it shows the best parameters. Please make sure you used the exact values shown there. If problem still exists, please send us an email with file attached with this post link.
March 8, 2022 at 7:39 pmwilliamfraser3
SubscriberThis fixed my problem. Thank you!
- Error on Lumerical device
2564
2078
1293
1106
459
