August 27, 2019 at 7:08 am
HannahFluent
SubscriberHi
I am trying to optimize the geometry of a combustion chamber to maximize combustion efficiency. It is a conjugate problem and therefore has domain interfaces . I have made a length of the geometry a parameter. When I try to change this parameter in the parameter section on workbench, and update the solution, the mesh interfaces are deleted (they are unmatched) causing errors. The length that is a parameter is on the interface.
August 28, 2019 at 12:07 pm
Ansys EmployeeHave you labelled the interface zones (surfaces) with "interface" as part of the boundary name? Which solver are you working with?
August 28, 2019 at 12:12 pm
HannahFluent
SubscriberNo. However I have changed there type to 'interface' and match them, this is undo when I reload the set up. I'll rename them now to see if it helps. Pressure based ,absolute, steady, axisymmetric.
Thanks for the help
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1349
1118
461
