Process Integration and Design Optimization
Optislang and designXplorer
    • Sahithi Pampatwar
      I am doing sensitivity analysis on my model and am confused which one to use optislang or designxplorer?
      what is the difference between them? which one is better? and why?
      for ex, i want to observe heat flux by changing material properties
    • Ashish Kumar
      Forum Moderator
      Both Ansys optiSLang and Ansys DesignXplorer serve the purpose of performing optimization and sensitivity studies. OptiSLang is a powerful tool for optimization, statistical analysis, and process integration, whereas DesignXplorer is an integrated Ansys Workbench tool for parametric analysis and optimization studies. When deciding which tool to use, it's essential to consider the specific requirements of your analysis, simulation setup, and desired outcome. OptiSLang might be more suitable for complex optimization problems or when you need to incorporate different tools into your workflow, whereas DesignXplorer may be more appropriate for simpler optimizations or work within Ansys Workbench.
      Ashish Kumar
    • Markus
      Hi Sahithi,
      here you find a summery of the capabilities:
      The algorithms of the DesignXplorer are included in Ansys optiSLang.
      So DesignXplorer includes a subset of the capabilities of optiSLang.
      I hope this helps with the decision.
      Best regards,
      Markus
    • Sahithi Pampatwar
      Thank you so much for the answers.
      I am using ansys student, there is no optislang in that package. So I can use optislang only when I purchase the license, or is there any other way?
      Regards
      Sahithi
    • Markus
      Hi Sahithi,
      optiSLang is not included in Ansys Student, but Ansys optiSLang is included in the Academic Bundles:
      https://www.ansys.com/content/dam/amp/2023/january/quick-request/academic-product-bundle-reference-table-4-11-23.pdf
      You can check with your University/your Institute if they are available.
      Or you can request a 30-day free tail here:
      Engineering Simulation Software | Ansys Products
      Best regards,
      Markus
Viewing 4 reply threads
