March 17, 2023 at 7:35 pm
Jacob Ellis
SubscriberHow do we run an Optislang DoE with materials as a discrete parameter? I load several materials into Mechanical, make the Material Assignment a parameter, and attach an Optislang block. But parameter in Optislang shows the material is a single discrete option and not a list of the several I loaded.
It appears properly as a list in the Parameter Set in Workbench
But if connect an Optislang block I can't seem to figure out how to have it optimize from the list
- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
3720
2570
1783
1236
594
