April 23, 2020 at 3:45 pm
amir_ms81
SubscriberHi, I have installed Ansys 2019R1 and Optislang8 on Linux. both works fine seperately but the problem is that I cannot see optislang inside the workbench like windows. is there any compatibility issue in Linux between ANSYS and Optislang? Thanks -
April 23, 2020 at 6:58 pm
dsurendr
Ansys EmployeeHello,
Please check if you have the AWP_ROOT193 environment variable set to the 2019 R1 installation path. This should enable the Workbench plugin option when you run the Optislang installer again.
April 24, 2020 at 5:07 pm
amir_ms81
SubscriberI did it. I used "export AWP_ROOT193=/opt/ansys_inc/v193"
now, I manually installed the optislang extension and it works fine but it seems every time I have to add the extensions to my workbench.
April 25, 2020 at 12:34 am
tsiriaks
Ansys EmployeeYou should be able to set it to add by default. In the ACT page -> Manage extensions, there is a small arrow on the bottom right of each ACT tool, there you can select to load as default.
- Local Sensitivity and Sensitivities: what difference?
- How many designs are generated while performing optimization using Optislang with NLPQL?
- DesignXplorer vs optiSLang for Workbench CFD Optimization
- Optislang workbench add-in
- Parameter relationships for Optimization
- ANSYS Optislang
- DOE all design points give the same results as the first calculation
- Errors about integrate executable into ANSYS Workbench using ACT
- Parametric study: Batch mode
- Design of Experiment points: Design Exploration
3648
2534
1745
1226
578
