February 21, 2023 at 4:42 pm
Kail Break
SubscriberHow do you move an object in a circle during the simulation to model orbital shaking? Even a link to a video where someone moves soemthing in the simulation would help.
February 21, 2023 at 4:53 pm
Ansys EmployeeThere are a couple of tricks using sliding mesh in Fluent. Please post a sketch of what's moving and the motion path.
February 21, 2023 at 6:34 pm
February 21, 2023 at 6:38 pm
Kail Break
SubscriberI have the mesh set up and the model initialized. I just need to shake the model.
February 22, 2023 at 9:42 am
Ansys EmployeeSo, the outer casing is fixed and the core moves on an eliptical path? Or the whole lot moves? For the former you may need moving mesh, for the latter it's more a case of sliding mesh and reference frames.
February 22, 2023 at 6:34 pm
Kail Break
SubscriberThe whole lot moves.
February 23, 2023 at 9:58 am
Ansys EmployeeOK, what you need to do is cheat. We can mess with gravity, but that needs UDFs. If you can break the motion into circular sets what you can do is use sliding mesh and mess with the relative motion. You may need a "dummy" block of solid with a very coarse mesh to do this. Have a look for the vertical axis wind turbine (VAWT) threads as that's how we do those.
3744
2573
1793
1236
594
