June 10, 2022 at 2:32 pm
cbur
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
One of our customers has a very strange problem:Â
In an internal design: the origin of the component and the origin of the design are not parallel even though they share the same origin!
There is no error in the geometry and I have looked at the installation log files and I don't have an error log that could explain this problem.
Do you have an idea or at least an explanation?(Ps: Problem between the origin of "equerre 1" and the origin of the design)
Â
Regards
June 10, 2022 at 3:55 pm
Subashni Ravichandran
Ansys EmployeeHello charlie
Let me check the geometry and get back to you.
Was the geometry imported from a different format?
June 13, 2022 at 11:44 am
cbur
SubscriberHello, SubashniÂ
All the parts have been designed in SpaceClaim and internally in the design, there are no imported parts in this model.
July 28, 2022 at 10:05 am
3930
2649
1863
1272
610
