September 21, 2018 at 8:11 am
tcs engineer
SubscriberDear members,
I am trying to do thermal analysis of electronic card/board using Ansys fluent.
I come across thermal conductivity in-plane and out-plane.
Please can any one explain me which is the best approach to consider.
If you say its orthotropic can any one give me some explanation on an-isotropic and orthotropic
VIJAY B R
September 23, 2018 at 12:36 pm
SubscriberHello Vijay,
If you have conductivity data for the PCB material in different directions, then you can use that. Say the thickness of the PCB is in the Z direction, and say the conductivity is much lower through the thickness than along the plane, then you would create an orthtropic material.
If you don't have any directional data, then you have to use an isotropic material and the conductivity is no different through the thickness than in-plane.
Note: I just made up these numbers to illustrate the concept.
You have to find some actual data for the material you are using.
September 23, 2018 at 4:03 pm
September 23, 2018 at 7:00 pm
SubscriberLooks good.
September 24, 2018 at 9:59 am
Ansys EmployeeIf you click on the Help button in R19.x and follow the links it'll give you some more information: you've got it right though assuming you got the directions correct.
September 24, 2018 at 10:12 am
tcs engineer
SubscriberThank you for the solution,
i request you to comment on my another problem post.
VIJAY B R,
2666
2120
1349
1132
461
