Ansys Products
Ansys Products
OS dependent license error
    • l_koers
      Hi all,
      I usually work from my Windows laptop and use remote sessions of Fluent 2021R1 to solve on a HPC server (RHEL8) which also serves as the license server.
      Because we had a temporary 2021R2 license for some time in 2021, LM 2021R2 is still installed. I ran ans_uninstall212 to get rid of all R2 products.
      When I connect to the server by a PuTTY and VNC connection I'm able to boot workbench 2021R2, no toolboxes are available since I uninstalled all products but no errors are given as well.
      When I boot workbench2021R1 or Fluent 2021R1, I get license errors. Keep in mind I can launch Fluent R1 in remote parallel mode from Windows.
      Workbench 2021:
    • George Karnos
      It sounds like something still needed was deleted when the uninstall happened.
      Does /ansys_inc/shared_files/licensing exist?
      Does the /ansys_inc/shared_files/licensing /ansyslmd.ini exists? Is the hostname in this file the correct hostname of the current license server?
    • l_koers
      Hi Geo Thanks for your suggestions.
      The licensing folder is there on the Linux server and containing the .ini-file. Which is empty however, strange.
      The .ini on PC contains:
      ___________________________________
      SERVER=1055@xx.xxx.xx.xx
      ANSYSLI_SERVERS=2325@xx.xxx.xx.xx
      I copied this to the .ini on the server but the problem persists.
    • George Karnos
      Under $home/.ansys you should see License debug files.
      Check the licdebug.FLUENT.211.out file for errors and post them.
Viewing 3 reply threads
  • The topic ‘OS dependent license error’ is closed to new replies.
