OscillatingPlate.agdb file access?
    • up2017
      Hello,nI am currently looking at a tutorial online called 'ANSYS System Coupling: Two Way Fluid Structure Interaction'. It requires me to download a file called 'OscillatingPlate.agdb' which seems to be available through the ANSYS Customer Portal. I am using ANSYS through my university, does anyone know how I can get access to this file?nI tried creating my own design but ended up having problems in the dynamic mesh and data transfer setup.nThank you in advance!n
    • Karthik R
      Administrator
      Hello,nPlease connect with your Professor or Admin and they should have access to the Customer Portal. They should be able to help you download these files. nThank you.nKarthikn
    • DrAmine
      If you are in Fluent, Hit F1 and you will get to the help. Here you can get to the tutorial files.n
    • DrAmine
      https://forum.ansys.com/discussion/3978/how-to-access-the-ansys-online-help#latestn
    • up2017
      Thank you for your help!n
Viewing 4 reply threads
