October 18, 2023 at 7:39 am
October 18, 2023 at 5:23 pm
Guilin Sun
Ansys EmployeeThis is physical, since there is a gap between the thin film and the PML. This means you are simulating a cavity formed by the thin film. Please make sure the thin film has substrate or not. Even with substrate, under proper conditions, such "oscillation" can happen when there is resonance.
When there are air gaps the cavity ends are in air/background material. When there is a substrate, one end of the cavity is in the substrate whereas the other one is still in air. Anything that forms two materail interfaces potentially can have resonance in broader spectrum, when it fulfils optical-path-difference is integer number of wavelength.
October 19, 2023 at 6:17 am
SAURAV GAUTAM
Subscriberthank you,
i have slight confusion about cavity formation because PML supposed to absorb all input field so what's causeing the interference?
there's no substrate, i just want to measure transmitted field, so is possible to modify measure geometry and get those value for different wavelength.
October 19, 2023 at 3:30 pm
Guilin Sun
Ansys Employeenot the PML, but the material interfaces that forms the cavity. Think how a typical cavity is formed. The thin film without substrate is the same. If you follow the cavity R/T derivation processs, you will know how the formula acts and where the phase difference is created.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
8808
4658
3151
1680
1470
