November 15, 2019 at 7:03 am
Liam1
SubscriberHello all,
I am simulating a structure with two lumped ports:
Solution type: terminal
Radiation boundary: a quarter wavelength away from each face
S11:
I don't understand where all these oscillations and resonances come from. When I change the size of the radiation boundary to be exactly as large as the structure (offset=0, all the faces touch the surface of the structure), the oscillations disappear:
I tried different meshing techniques and the oscillations are still there.
Any idea what's causing this and how to resolve?
Thank you
November 15, 2019 at 7:09 am
slouie
Ansys EmployeeThe lumped ports don't look to be defined correctly. Please see File>>Open Examples>>HFSS>>Signal Integrity, Connector model. The lumped port should be no wider than the trace width and height extent should be between trace and reference plane. Hope that helps.
November 15, 2019 at 6:18 pm
Liam1
SubscriberThank you slouie for your reply.
I found the example, and redefined the ports:
S11:
I think the root of the problem is the radiation boundary.
With the new ports, if I make the radiation boundary small to touch all the surfaces of the structure, the resonances disappear as well.
Any suggestions?
Best,
- Maxwell, HFSS or Q3D?
- Error
5340
3345
2471
