3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
OSDM files
    • GUICAD
      I try yo open in Discovery, SDAC and  SDPC file format and i get this error :
      Have you an idea ?
    • Atharv Joshi
      Forum Moderator
      Hello GUICAD ,
      If it's possible, can you please share the files? I will check it at my end and get back to you.
      Thanks and Regards
    • GUICAD
      Hello Atharv ,
      Sure, here it is.
      🛈This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions
    • Atharv Joshi
      Forum Moderator
      Hello GUICAD ,
      Thanks for sharing the files. I will check and let you know.
    • Atharv Joshi
      Forum Moderator
      Hi GUICAD ,
      Do you have Creo installed on your machine? If its installed, then it should be able to import in Discovery Successfully.
      If its installed, then please check CAD configuration from the following path.
      Start Menu>> Ansys 2023R1 Folder >> CAD configuration Manager >> Check Creo Elements/ Direct Modeling >> Move to CAD Configuration >> Configure Selected CAD Interface.
      Then try importing files in Discovery. Let me know if you face any issue.
      Thanks and Regards
Viewing 4 reply threads
