August 30, 2018 at 5:04 pm
amiyaabhash
SubscriberHi All,
I was exporting a 3d geometry from "hyper mesh" which is already 3d meshed into fluent. but after scaling the mesh to "millimeters" as my model geometry was made in millimeters, it is showing out of date mesh. anyone knows how to resolve an out of date mesh?
August 31, 2018 at 10:03 am
Keyur Kanade
Ansys EmployeeHi,
Can you please explain. Did you import hypermesh mesh file in Fluent?
Where did you change units - in hypermesh or in Fluent?
Which version you are using?
Keyur
September 1, 2018 at 4:27 am
amiyaabhash
Subscriberyes sir,
I imported mesh file from hyper mesh in fluent and in general section in fluent scaled the mesh as my geometry was created in "mm" and fluent by default takes meters.
ansys 18.0
hypermesh 13
September 3, 2018 at 2:59 pm
Ansys EmployeeIf you're just reading the mesh into Fluent there shouldn't be a mesh box/object to be out of date. Please can you post images of the Workbench session?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2616
2098
1323
1108
461
