March 15, 2021 at 2:49 pm
soloviev
SubscriberHello,
I was previously discussing this in another thread and was asked to create a new thread. I skinned a CAD faceted body and have an upper fluid region and lower solid region (all one part and shared topography). I loaded the mesh into fluent and got a weird 'outer' wall body for the bottom solid body (see photo). Will this interfere with the model run?
March 15, 2021 at 3:52 pmRob
Ansys EmployeeWhere is it in relation the rest of the model? nMarch 15, 2021 at 6:01 pmsoloviev
SubscriberIt seems to auto-generate around the edge/perimeter of the solid zone.nMarch 15, 2021 at 9:04 pmsoloviev
SubscriberI went ahead and ran the model and when I look at the results, I don't see this wall in the wireframe in CFD post. I'm guessing it isn't influencing the calculations, but I did want to verify. nMarch 16, 2021 at 12:52 pmRob
Ansys EmployeeThere might be a missing surface label when you created the geometry. I've not seen this occur for any other reason, so double check the mesh in Fluent to see what's going on. nViewing 4 reply threads- You must be logged in to reply to this topic.
2706
2146
1357
1144
462
