Outflow report with ‘pressure’ outlets (Discrete Phase Model)
    • shadowfax7
      Hi
      I have a geometry with multiple 'pressure' outlets. During my transient simulation, I want to calculate the amount of flow going through each outlet for the entirety of the simulation length. However, since I am modelling particles inside my fluid, I have 'Discrete Phase Model' enabled. Therefore, if I use the 'Mass flow rate' report, will the flow rate reported also include the particle mass? I just need information on the amount of fluid - not the particles. Do you have an idea how I could get that information?
      Mass flux on the boundary is the fluid flux, if you want the particle mass you'll need that separately.
