September 19, 2018 at 7:25 pm
birbara2
SubscriberHello I am considering a problem where I have a square pipe that has a given inlet velocity and I want to assume a profile for the outlet velocity. How can I specify that on the outlet? also what is the difference between outflow and outlet vent ? what are the physics behind it?
Thanks
September 19, 2018 at 10:54 pm
Karthik R
AdministratorHello,
Why are you trying to assume an outlet velocity profile? What is the purpose of your simulation?
About the difference between outflow and outlet vent:
Outflow - Outflow boundary conditions can be used at the outlet of open channel flows to model flow exits where the details of the flow velocity and pressure are not known prior to solving the flow problem.
Outlet vent: Outlet vent boundary conditions, as the name indicates, are used to model an outlet vent with a specified loss coefficient and ambient (discharge) pressure and temperature.
You should be able to read more about these BCs on the ANSYS Fluent Users guide (Section 6.3 'Boundary conditions', R18.2).
I hope this helps.
Best Regards,
Karthik
September 20, 2018 at 2:57 am
birbara2
SubscriberBasically it is a condensation and evaporation problem. As we evaporate at a certain rate, we get a velocity of vapor. I know the evaporation rate but I don't know the condensation distribution on the other side. So I want to check different profiles at the exit since I don't know that. Do you think I can do that? Also, is the outflow solution UNIQUE? or is it one solution
Thanks
2600
2088
1319
1108
459
