Discovery Import
Discovery Import
Outlet pressure condition
    • rajnarayang
      Is the outlet pressure condition in Discovery Live gauge pressure or absolute pressure?
    • Charudatta Bandgar
      Hello Raj Narayan G ,
      At the outlet, you can use both absolute as well as gauge pressure, as long as it is static. The measurements will be shifted by 1bar based on the pressure measurement type you are using and provided you have consistent type throughout the fluid domain. If you are specifying inlet pressure as well, then it needs to be total pressure and not static (be it absolute or gauge, as long as it is consistent with the fluid domain).
      Regards.
