Preprocessing
Preprocessing
Outlets and body of curved pipe not visible in the Fluent Setup
    • Attiya221
      I am trying to simulate water flow through a curved pipe with a conical sweep.
      I built the geometry using Rhino6, it generates drawing with .igs and many other extensions that Ansys Fluent can read. The final geometry was a poly-surface. I can import it and generate a mesh and an inflation, but when I reach the Setup stage, the Named Selection edges of the inlet and outlet are not visible in Boundary Conditions. I also struggled to generate the Boundary of the body since it only recognizes it when I use Smart Select for the mesh and the inflation.
      I am hoping to get a velocity profile of the water flow but since the inlets are not recognizable, the Contours can not be generated.
      please let me know if you need any files or information to help with this enquiry.
      Is this 2d or 3d?  Please post some screen shots.
