Output and input of ISAT table data
    • admin
      Here are the ISAT (In situ adaptive tabulation) table data Output and Input methods: 1. Output Method. Run the following TUI command, then specify an output filename: /file/write-isat-table. 2. Input Method. Run the following TUI command, then enter the input filename: /file/read-isat-table
    • admin
      How to output and input ISAT table data?
