Ansys Free Student Software
Output complex eigenvectors
    • ReneSe
      HellonI'm doing a modal analysis and want to plot the strukture with the mode in matlab. Therefor I am exporting all my node connections and put them in a scatterplot in matlab. All fine.nNow I need the X,Y and Z values for the moving of the node connections for every mode. I tried with simply exporting the result of each deformation, which gave me only the absolute maximum for every connection.nI then found a command to use in my solution but it won't work. I always get the error that N is undefined. The code is...nrsys,solu n nall n /output, ev_real, eig n *do, i, 1, N n set,, i n /page,,, 10000000 n prdisp n *enddo n /output, term n /output, ev_imag, eig n *do, i, 1, N n set,,i,, 1 n /page,,, 10000000 n prdisp n *enddo n /output, term nfinishnnI put this in a command in the solution tree in workbench. If I change N to any value, workbench will stop at 10% processing.nAny one got an idea how to get the complex eigenvector in any way?n
    • ReneSe
      I just realised I posted this in the wrong area. If a mod could delete this one, that would be nice n
    • tsiriaks
      No problem. Thank you for your message.n
