November 10, 2023 at 3:24 pm
Ahmed Salama
SubscriberHi, I am using lumerical FDTD. I need to find the relation between input intenisty and output field for a raman/kerr model. I used the script from Ring resonator - optical bistability to show the relation between input and output, but the following figure appear.
This figure is not making sense becasue the output is greater than the input. I am using a single intensity (0.5e14 W/m^2) and this is the source
I am using also single wavelength of 1550 nm
and this is the material definition
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3153
1680
1470
