Output frequency spectrum automatically after harmonic analysis
    • hmpws
      At the moment, I have a harmonic analysis and the frequency spectrum for Z directional velocity on a named selection gives me the exact values that I require for further processing. I can manually export the frequency/amplitude/phase table.
      However, I like to run a parametric study and would like the table to be exported automatically.
      How do I average the data on the named selection and export them? I looked at the documentation and /post26 seem to have the required.
      I imagine it is something like this:
      /PREP7
      ALLSEL,ALL  ! select everything
      CMSEL ,S, ns_region
      FINISH
      /POST26
      ????output averaged frequency, amplitude and phase of selected nodes????
      Thanks.
    • Rohith Patchigolla
      Please try the below script.
      This script gets the Average frequency Uy response (for example) of a named selection (having a set of nodes).
      You can modify it as needed. Hope this helps.
      Best regards,
      Rohith
      /POST26
      FILE,'file','rst'
      NUMVAR,200
      SOLU,191,NCMIT
      STORE,MERGE
      FILLDATA,191,,,,1,1
      REALVAR,191,191
      LINES,99999,
      !Provide the named selection name below
      CMSEL,S,MySelection
      *GET,nodeNum,NODE,0,COUNT
      CURR = 0
      *DO,I,1,NODENUM
      CURR = NDNEXT(CURR)
      !Result quantity being extracted for the frequency response curve, in this case, Uy
      NSOL,3,CURR,U,Y
      *IF,I,EQ,1,THEN
      ADD, 4, 3
      *ELSE
      ADD, 4, 2, 3
      *ENDIF
      ADD,2,4
      *ENDDO
      PROD, 5, 4, , ,UY, , , 1/NODENUM
      !Create text files in solver files directory
      PRCPLX,0
      /OUTPUT,Frequency_Plot_real_im,txt
      PRVAR,5
      /OUTPUT
      PRCPLX,1
      /OUTPUT,Frequency Plot_ampl_ph,txt
      PRVAR,5
      /OUTPUT
    • hmpws
      Thank you very much! It is so much nicer to find example code to work with. I had to add NSLE in the line after CMSEL to make this work but other than that!
