October 16, 2018 at 7:09 am
Naveed
Subscriber -
October 16, 2018 at 8:29 am
Ansys EmployeeCheck what you're monitoring as velocity magnitude will always be positive. How does the frequency compare to the input signal?
As an aside, adding a tag to show which code you used will help the community assist you.
October 16, 2018 at 8:35 am
Naveed
SubscriberRwoolhou, thanks for your answer. I am new to ANSYS. In mechanical, from the solutions (in the outline tab) I added "total velocity". Frequency is constant. My input remote displacement is: 7.5*sin(40*time).
I made a geometry. No code is used here. -
October 16, 2018 at 11:00 am
Ansys EmployeeThanks, by code I mean which of Mechanical, Fluent, CFX, HFSS etc did you use: sounds like it's Mech so I'll tag this for the community.
I suspect total velocity will always be a positive, but the vector will change.
October 16, 2018 at 11:47 am
SubscriberPlot Directional Velocity instead of Total Velocity to get a sinusoidal output for a sinusoidal input displacement.
October 17, 2018 at 2:59 am
October 18, 2018 at 6:11 pm
SubscriberThe top graph is plotting a value of zero with some numerical error mixed in.
What is the output scoped to and what are the boundary conditions? -
October 22, 2018 at 3:16 am
Naveed
SubscriberThanks a lot Peter. After selecting directional velocity I need to specify the axis. After selecting Y axis it is showing the results as were expected. Thanks man.
2098
1323
1110
461
