Output result for each point
    • jojo
      I am a beginner using ANSYS Mechanical. I am doing static magnetic field analysis. I want to output the magnetic field value for each point. What should I do?
    • Karthik R
      Administrator
      Which tool are you using? Ansys Electric or the Electromagnetic Suite?
      Thanks.
      Karthik
    • jojo
      I use ANSYS Electric .
      Thanks fo reply.
    • HuiLiu
      Hi Jojo,
      Could you confirm if you are using the highlighted module? The available results for Electric can be found here: link.
      Or are you using this instead? Available results for Magnetostatic can be found here: link
    • jojo
       Hi HuiLiu,
      I am using the latter.
      Thanks to your help, the problem has been resolved.
      Thank you.
Viewing 4 reply threads
