March 1, 2023 at 11:04 pm
Zan Gorensek
SubscriberI am working on a project, where I have a box with water. The water circulates with help of a pump. In the box there is a body that gives out heat. I have 1 Inlet and 1 Outlet. I would like to connect the temperature of water on inlet to the temperature of water on outlet. So that i can have a mixing fluid, which is warming up and as water's temperature rises, the temperature on inlet also rises. I decided to ask here, because I am lost and can't find out how to do it.
March 2, 2023 at 9:56 am
Zan Gorensek
SubscriberAlso i am using discovery live
March 2, 2023 at 1:24 pm
SRP
SubscriberHi,
I suggest you can try to create exceute command and update the boundary condition with each time step.
For more details, please refer to fluent user's guide: 33.17. Executing Commands During the Calculation (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Thank you
3850
2609
1853
1246
600
