October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeFor outputting the single value of tension/compression in a spring, instead of the two opposite values at its nodes, you can use the ETAB command as it is a MISC result. O the PRRSOL command prints the reaction forces if one of the nodes is constrained.
October 4, 2017 at 2:39 pm
nselvara
Ansys EmployeeHow can you output the tension/compression of a spring in MAPDL?
2104
1327
1110
461
