May 8, 2023 at 11:19 pm
kobay000
SubscriberHi folks, I have been getting errors in transient 2D analysis. I need to calculate the d-q inductances of an ipm machine by coordinate transformation technique. However, when I try to get a rectangular data plot of the output variable, it gives me an error that implies there isn't any related solution about inductances. Contrary it gives me the plots of winding inductances without any problem. When it comes to calculating the output variable with this existing data it does not exist! I have set the apparent matrix calculation in design settings too. Any help, please?
May 17, 2023 at 1:26 am
HDLI
Ansys EmployeeHello kobay000,
1). Could you verify if you have L inductance results in report?
2). A workaround solution might use “/1H” for inductance calculation, like L(Winding_A,Winding_A)/1H, to convert it to non-unit quantity. H is unit of Henry.
Thanks
Howard
May 18, 2023 at 10:47 am
May 18, 2023 at 1:15 pm
HDLI
Could you show your equation with /1H? Please just leave a simple one in output variable and delete others. Thanks.
Howard
May 18, 2023 at 2:19 pm
May 18, 2023 at 2:24 pm
HDLI
It seesms to me you can plot "test", just do not have the result.
Do you have results? Do you have the errors again? Thanks.
Howard
May 18, 2023 at 6:50 pm
kobay000
SubscriberHi,
As I mentioned before I have the calculated values of inductances. However, when I plot the output variables which consist of calculated inductances, there is nothing (please check the screenshots in the first post). Also, the error has disappeared in "test" variable. Thanks.
May 18, 2023 at 7:00 pm
HDLI
Please rerun the simulation to get results, and then I believe you will have output parameter with /1H. Thanks.
Howard
- Maxwell, HFSS or Q3D?
- Error
5282
3299
2469
