February 15, 2022 at 2:05 am
ROSELJR
SubscriberViper22a replaces 12a with higher output voltage, do not know the reason?
https://www.utmel.com/components/viper22a-smps-controller-ic-circuit-equivalent-and-datasheet?id=566
February 22, 2022 at 9:32 amAshish Khemka
Can you elaborate more on how Ansys is related to this change?
Regards Ashish Khemka
- Maxwell, HFSS or Q3D?
- Error
3720
2570
1783
1236
594
