November 8, 2023 at 5:32 pm
Simon Martin-Dye
SubscriberIf I have a co-worker that has a project setup with pressures/loads/constraints, can that be output into Discovery so I can also run it?
November 9, 2023 at 2:23 am
Charudatta Bandgar
Forum ModeratorHello Simon,
I am not sure if I follow your question right.
If you are asking if the Setup made in workbench can be transferred over to Discovery that wont be possible, you can export the geometry and you will have to do the setup again. Although you can transfer the Discovery setup to mechanical, through the transfer to mechanical option available in Discovery.
If you are asking whether the results of workbench be exported and applied as a load, etc. that also is not possible in Discovery.
Let me know if my understanding of your question is correct.
November 9, 2023 at 12:39 pm
Simon Martin-Dye
SubscriberI think you are understanding. I was hoping I could get the setup of the loading with constraints, pressure loading so I did not have to set up the analysis over again
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8762
4658
3151
1678
1456
