/OUTPUT yields values of zero for getting EQV stress.
    • KevinG
      Hello everyone,
      So, I have a lattice structure comprised of a number of members using beam188. When I use the following code by typing into the command prompt;
      /output,res.txt
      LSEL,S,LINE,,1,1
      ESLL,S
      *GET, SVM_MAX, SECR, , S, EQV, Max
      /out
      I get the maximum equivalent stress for a selected member in my res.txt file. However, when I run this as an input from matlab, I get the following error in res.txt;
      The requested beam or pipe data is not available.  Parameter SVM_MAX will be set to zero.
      It's strange because it works fine on another version of Ansys, however I don't have access to this version. Can anyone help?
      Thanks.
    • KevinG
      Found the solution. For some reason, no etable data is available when running distributed computing. I manually changed to shared-memory parallel and this solved the issue. This link was very helpful; https://www.padtinc.com/blog/starting-ansys-products-from-the-command-line/
